PRO-95 And PRO-2096
southeastjuggalo1
Marietta, Ohio
I am looking for someone out here that might be able to help me with programming my scanners.
I have been trying to pick up "Marietta Post OHP" and for some reason the Freqs I put in doesn't seem to work or I'm doing something wrong. Could someone help me out please. PS I would like all my surrounding Freqs for this area. I'm in Southeast Ohio
KI5FKE
Beaumont, Texas
Are you programming it as a Motorola trunked frequency or a conventional frequency?
wa8pyr
Staff member
Lead Database Admin
Ohio
The Pro-95 will not work for OSP as it is not digital capable (OSP is on Ohio MARCS).
For the Pro-2096, make sure the system is set to Motorola Type II and that you have the control channel frequencies for the sites in Washington County properly programmed.
KI5FKE
Beaumont, Texas
Make sure that you set the trunk mode to Motorola when programming. You only need the use the control channel frequencies.
southeastjuggalo1
Marietta, Ohio
Ok I think my PRO-2096 is working correctly and I'm guessing the PRO-95 don't pick up what I'm trying to pick up because it is a dual trunking
KI5FKE
Beaumont, Texas
So are you receiving any traffic on your Pro-2096 from the Ohio MARCS - Multi-Agency Radio Communications system?
KI5FKE
Beaumont, Texas
You can look at eBay; that's where I got my Pro-2096 from. Had it since October of 2012 and is still operating. I am looking for another digital scanner so that I can monitor without missing anything.
southeastjuggalo1
Marietta, Ohio
I called my local Radio Shack and they said $110.00 was the cheapest and it was a PRO-404 not sure if that's a good one or not tho
