Pro 95 need help
misterial
Okay I have no idea what the deal is here. My scanner is dead. I changed the batteries. Nothing happens when you power it on. But after a week or so of fustration, you power it on it lights up says its welcome screen but freezes on that screen you can hear some sort of audio but never boots into normal mode. I had a friend look at scanner who is a licensed radio technician, he said he needs the schematic for this which we cant find on the web. He does not know what the problem is yet. Has anyone had this happen to their scanner? I dont even know what RS charges to repair issues. Any help?
n3ncn
Trinity,North Carolina
Here is what the owners manual says to do in case the 95 freezes up . Scanner Reset Contents
If the scanner's display locks up or does not work properly after you connect a power source, you might need to reset or initialize it. If you have problems with the scanner, first try to reset it to retain the memory.
To reset the scanner, turn off the scanner then turn it back on. Insert a pointed object, such as a straightened paper clip, into the reset opening above and to the right of the power jack on the side of the scanner. Then gently press and release the reset button inside the opening.
Warning: Initializing the scanner will clear all channel memories and reverts it the state it was in right out of the box.
To initialize the scanner, turn off the scanner then turn it back on. Press 0 then 1 when the welcome screen appears. Initializing Please Wait appears for about 2 seconds. Do not turn off the scanner while it is initializing. The display should then show M000 on the top line and Bank 0 CH 00.
fmon
Silent Key Jan. 14, 2012
Eclipse, Virginia
I have the schematic in pdf format, check your PM for sending me an email which I can attach the pdf in return email.
