Pro 95 programming issues
Kmmckay
Good day,
I am trying to program my pro 95. I have entered all the freqs for the trunked system I'm trying to listen to. When I try and change the mode of each channel to MO it only switches between AM and FM. It won't change to MO. Any suggestions?
N8IAA
Fortunately, GA
What trunk system are you trying to program? Are you following how the manual tells you to program a trunked system?
Need to know to help.
Larry
Kmmckay
Programming issues
The trunked system is a Motorola II smart zone. I'll have to check over the manual again. They really don't make these units easy?
kc4jgc
Virginia Beach, VA
On the '95, a bank has to set for either normal or trunked (Motorola or EDACS). In your case you have to program a BANK for motorola mode first. Then when you program the system freqs, you can program each freq as motorola.
In the manual, refer to pages 57-60.
