Pro-96 CPU version
xpawel15x
Is there a way to tell what CPU version a Pro-96 is without pressing the button combo. For example when buying the scanner on ebay or in a radioshack, can you look at the serial # and know what CPU the scanner will be? Does anyone know starting from which serial numbers will the scanner have the newest CPU?
iMONITOR
Silent Key
S.E. Michigan
When buying a PRO-96 in Radio Shack (I've bought several over the years), I either bring a set of batteries, or buy a set in the store, open up the scanner, pop them in, and run the check. They never seem to mind. I don't think an eBay seller should object doing that for you if you ask.
rdale
Lansing, MI
I don't think a CPU of 1.0 was ever released - try again...
Hmi, NO, not unless you ship it back to RS & pay lotsa $$$:(. if stll new & under warranty you will be able to get it done for free. be very Explicit when you take it in ( type exactly that you want done to on a sheet of paper & make sure THE person at Radio shack puts that with the radio when the ship it out. you're mileage may vary.. The guys at the shack I go to actually listen to me & realize I may know more them ie they are nice & very cool. I actually did this back when I had the pro 93 & was in warranty & didn't cost a penny
hcpholder
My CPU version is 1.2! Do I have to send it to Radio Shack for the version Change? Does anyone know how long it usually takes for the change to be completed (how long will I be without my radio)? thanks.
Hcpholder, probably looking at 2-3 weeks & will cost $$$, unless still under warranty. also make sure ur talking about CPU version NoT the DSP CPU version, press 3 after turning scanner on to see
EMS911
Houston,TX
Can someone tell me why I would need to send my P96 back for the CPU upgrade? (what benefit(s)); seems to work pretty well right now, but is still under warranty. Mine is ver 1.2.
iMONITOR
Silent Key
S.E. Michigan
You know the old saying... "If it works don't fix it!"
CPU v 1.5 was to fix a unique issue that surfaced in Michigan, and Ohio. The ones in-between I don't think were anything to worry about.
hcpholder
CPU Upgrade
Ok, I have family in Michigan that I go visit every year. I always take my Pro-96, so should I go ahead and have the CPU upgraded if I plan on listening to systems throughout Michigan?
xpawel15x
If it obviously causes problems to those systems and you want to monitor it correctly than I would do it.
DaveIN
Founders Curmudgen
West Michigan
I have had no issues with the P25 voice with the PRO-96 as is in Michigan on MPSCS. Detroit CQPSK is another story however.
