pro 96 digital scanner programming
skirvy22
i programmed york county Pa fire dept talk groups into the RS pro 96. I used the program from radio reference. and a computer and i dont pick anything up., Any suggestions? Mayland and other PA counties work except York county.
lebrunmn
Retired... Get off my lawn!
Hampshire County, WV
Extended tables
Skirvy22-
Someone local may be able to give you better info, but I think you need to use Extended Tables (WIN96) for the York TRS... possible values:
Extended Tables
#00 CH LO 0, CH HI 65535, Base 500.00, Offset 0, Step 12.5
Found at:
PGHScanner
But that info may be a bit dated. Still doesn't hurt to try.
