Pro-96 no longer detecting frequencies
joepaigejr
Lorton,VA
My Pro-96 has stopped recognizing any kind of comms. I even manually selected the CC on 2 separate TRSs in my area, and they were not being decoded. No sound, nada. This also happened last weekend for about 3 hours. Then all of a sudden, the scanner started working again, until today. Any thoughts?
Thanks,
Joe
AZScanner
Somewhere in this room. Right now, you're very col
Hmmm... might need a reset. Did you try that? Sometimes when a scanner goes beserk I do this and then just use the software to reprogram it again.
-AZ
david1975au
nsw australia
scanner not detecting freqs
dear sir, hi you could or might have a faulty scanner or software it haappens i know a guy who had a 780 similar to that ,thanks david1975au :)
DonS
Franktown, CO
Perhaps the CC is changing to a frequency you don't have programmed into the PRO-96.
I had this happen on my local system - it turned out that I only had the CCs listed in the RR database programmed, and the system started using one of the other frequencies as the CC. I ended up programming all eleven of the system's frequencies.
