Pro 96 V folders
Rod1111
Hello everyone. I am new to scanning and just got a pro 96 scanner. I have a newbie stupid question. I understand how to get the V folders to come up and I can change from one V folder to another but how do you get the V folders to go away and go back to orignal channels that I had programmed in the radio ?
rdale
Lansing, MI
You don't. Loading in a vfolder replaces what the scanner had with what you loaded.
fmon
Silent Key Jan. 14, 2012
Eclipse, Virginia
Welcome to the Board Rod, If you saved your working folder to the period (.) folder in V-Scanner as described in the first paragraph on page 4 of the Addendum, simply bring it back as you would with any of the numbered folders. However, if you did not save to this folder, then as Rob stated you're out of luck via default mistake. BTW we all have "All S_ _ _ " syndrome at times. :cry:
Rod1111
Thanks for your replies. From now on I will save all wanted freq. in the "notepad" folder.
