Septa3371CSX1
Yesterday I sat down with my Pro 97 in my back pocket. Next thing I looked the antenna jack came out of the scanner (for the record, I'm using the large RS rubber duck). I tried putting it back in but in the process, the red wire came off. Since then I have had poor reception on most channels, including NOAA weather radio which is coming in fuzzy. In an attempt to repair the unit, I managed to damage it further and two silver nuts came out. I didn't put them back in because I couldn't figure out exactly where they went. Right now, I'm operating my 97 with the bad antenna jack and while in some cases I can get what I want to listen to, I'm having trouble with trunk system control channels. Also depending on where I have the unit, I may or may not be able to pick up the stuff I am able to pick up with my 106 or 2055. Any idea on how and if this problem can be fixed? I really don't want to take it to The Shack because it is no longer under warranty, it's about 2 years old, and I'll run up a large bill. This is my main scanner and it has the battle scars to show. The belt clip housing is broke (thus I can't use the belt clip hence why it was in my pocket), the buttons on the keypad are worn out, and it has several dings and dents. I would like to be able to repair this if possible so I don't have to spend money on a new one. Thanks for all help in advance.
