PRO668 (PSR800 & WS1080?) Weak signal squelch problem
medson
Colorado
No operator error.
I can park on weak, slightly noisy analogue conventional channel and the squelch will open reliably at the 9 or 10 o-clock position. However, put the same radio in scan mode and it just skips over the weak busy channel/s. It completely ignores these weaker signals.
It is very annoying when scanning distant systems both using a base antenna and the rubber duck.
Find myself resorting to the Uniden scanners when I need to scan these systems.
There are a few things I like about the WS1080/PRO668 design, but this really does suck.
Elsewhere in these pages it is fixed! Set the Global AGC to OFF, Set Threshold High to 85% and the low to 55%
Use Radio Shack Black Rubber Duck Scanner Ant (800 MHz) for best reception.
KD0-OMN
DaveIN
Founders Curmudgen
West Michigan
I wonder if it's that specific radio (or a batch). My Psr-800 and BCD436HP sound identical and are able to capture the active Talkgoups nearly every time with the same RS800Mhz antennas.
Any chance your getting interference from another signal source?
