Pro97 backlight question
mkh
Rutherfordton NC
Is there anyway to have the back light come on anytime ti stops on a channel?
Is always on the only answer?
KC9LDB
for some odd reason, I most likely hit a button but, mine can do that. It's power save mode, thats what the display says, when you turn it on, it counts down than find out how to enable that and it should work...
"Your scanner features a power save circuit that is automatically activated after about 30 seconds if you have manually select a channel. The power save mode works by allowing the receiver to 'sleep' briefly while waiting for a call on the selected channel and will also turn the backlight off. The power save circuit is disabled when the scanner is tuned to a channel in program mode, scanning, or searching." (Easier to read Pro-97/2055 Scanner Manual.) > http://myweb.cableone.net/marksscanners/97/97.html#contents <
KC9LDB
"Your scanner features a power save circuit that is automatically activated after about 30 seconds if you have manually select a channel. The power save mode works by allowing the receiver to 'sleep' briefly while waiting for a call on the selected channel and will also turn the backlight off. The power save circuit is disabled when the scanner is tuned to a channel in program mode, scanning, or searching." (Easier to read Pro-97/2055 Scanner Manual.) > http://myweb.cableone.net/marksscann....html#contents <
Yeah this is the way mine did it...
mkh
Rutherfordton NC
OK How do you get it to activate?
I can't seem to get mine to do this. I even took it off AC to see if the power saver only works during DC operation. Still no luck.
madnachos
So California
The light does not go out when you are holding on a channel? Its either on or off while scanning, power save only happens while you are holding on a freq or talkgroup.
gmclam
Fair Oaks, CA
Press and hold LIT to turn the light on. Press MAN and select the desired channel. Wait. After there is no communication on that channel for a while, the scanner will go into power save and the light will go out. When there is a conversation, the light will come back on.
mkh
Rutherfordton NC
The manula says - power save circuit is disabled when the scanner is tuned to a channel in program mode, scanning, or searching." (Easier to read Pro-97/2055 Scanner Manual
I guess I was reading that line wrong. It can be read one of two ways.
