Problem programming Kenwood TK-3301
M0YDC
South UK
I received this TK-3301 ProTalk with some other stuff and only some channels worked which may have been standard, I don't know.
I downloaded the KPG-121D V1.01 software and have the engineers serial number (posted in another old thread) and programmed in the 446 MHz channels that I wanted. I have the correct programming lead.
Now it won't transmit, just the LED flashing Red but it will receive on all the channels and when a signal is being received the LED flashes Green then Amber and alternates and when the signal has gone it goes back to flashing Red. The same happens if I load the standard channels that the software comes with.
Now the strange bit.... in the software when in Test mode and using the software button to transmit, it does, solid Red TX LED and received signal on another radio. No flashing Red LED on standby and a solid Green LED or receiving a signal. Come out of Test mode and it goes back to the above posted issue.
Any ideas what the issue could be as I am stumped at this point?
Thanks.
