Problems programming Icom f-50v
katpar
tustin
I just acquired 5 icom ic-f50v radios .I can read the radios but cannot write to them .I have version cs-f50v mm version 3.11 software and the firmware version of the radio is 3.4 I have tried the software in a few different computers and used both a serial and usb programming cables .I have tried both high speed and normal speed high speed settings but nothing works .I even tried changing the bus speed of the cables to a lower baud rate in the settings and still nothing works .It seems the software knows the radio is there but in the display of the radio nothing changes when I attempt to write to the radios .all cables are opc-966
jeatock
090-45-50 W, 39-43-22 N
F50V / F60V software and firmware
Current radios use CS-F50V MM v3.1.1 software and FL3060A v3.6.2 firmware.
Current Software version: 3.1.1
Current Firmware version: 3.6.2
CS-F50V MM v3.1.1 should read all of the earlier V models.
I've had some non-V F50's that needed other versions. There is a bit of trial and error needed.
The current versions are:
Clone Software 2.1. (MDC)
Adjust Software 2.0 (MDC)
Note: Newer MDC cloning software has the same features as earlier, non-MDC cloning software and can be used for non-MDC operation in older radios.
CS-F50v1.6.zip application/x-zip-compressed 1,481.1 KB
CS-F50v1.1 adj.zip application/x-zip-compressed 2,193.7 KB
CS-F50v1.0.zip application/x-zip-compressed 1,480.7 KB
CS-F50v1.2.zip application/x-zip-compressed 1,471.2 KB
CS-F50v1.3.zip application/x-zip-compressed 1,471.6 KB
CS-F50v1.5.zip application/x-zip-compressed 1,480.4 KB
CS-F50v1.7.zip application/x-zip-compressed 1,481.1 KB
CS-F50ADJ MDCv2.0.zip application/x-zip-compressed 2,194.6 KB
CS-F50 MDCv2.0.zip application/x-zip-compressed 1,687.3 KB
CS-F50 Cloning MDC v2.1.zip application/x-zip-compressed 1,690.0 KB
CS-F50_MDC1200 inst sheet.pdf application/pdf 189.6 KB
Are you sure they're V's? (Model number on the tag and a silver bezel)
The bad news: Older F50 radios used in long term rough service with remote speaker/mics attached had an issue with stress breaking the solder joints between the side connector board and the main board. Some read/write fine, some have to be "Englished" forwards or backwards while programming (flex the side connector and hold your breath while reading/writing), and some just won't program without repair. If you are either skilled or fearless it is not difficult. Since Osaka changed that process four or five years ago, I haven't seen this issue with any of the V radios, but it is not impossible.
The good news is that is the only mechanical issue with the 50-series chassis series. I've worn the same non-V F50 daily since 2007. Only the battery, antenna and a couple knobs are not original.
ramal121
Lots and lots of watts
Calif Whine Country
From Icom:
  • F50V Software and Firmware Compatibility.pdf
retiredinsemo
This may seem strange but some of my Icom software refuses to read/write unless I switch to Comm1 in the device manager/software settings. My F14 and F121 are fine with Comm3 but my F3021 has a tendancy to hang up from time to time. No hang ups or error messages when switched to Comm1.
Hope this helps.
12dbsinad
The F50V/F60V's use a flex ribbon cable to feed the accessory connector versus being soldered on to the board. This has solved the issue with the V's, or at least I have not seen or heard of any issues.
jeatock
Haven't had a failure and needed to open one up like I have done oh-so-often with the original non-V series. That would 'splain why.:wink:
