sammy54322
- Joined
- Apr 4, 2023
- Messages
- 3
- Reaction score
- 0
I've recently got a Procom DPF 70/6 5-7MHz split duplexer and I'm trying to tune it with a NanoVNA-H4 and I'm having some issues with it. This is a fairly popular duplexer here so having never bought/tuned one before I thought it was a safe choice.
I have managed to tune the high side as best as I can with the dynamic range of the NanoVNA, however, the low side is causing me some problems that -3.5dB loss can never be changed now matter how much the adjustments are made.
I have calibrated the VNA a few times now over some different frequency ranges covering the two that I'm tuning for. I have also tried to tune for a different pair of frequencies and had the same issue with about -4dB loss. The metal where the tuning screws are mounted is also a mounting bracket which seems to have been dropped and is bent but the tuning screw looks to be perpendicular to the threads it is in. One of the low side tuning screws is also a fair bit harder to turn than the other 5 so all I can think is this might be part of it.
If anyone can tell me if it being dropped or bumped in shipping could cause this sort of issue that can't be fixed with tuning that would be really helpful. I suspect this was cheap on eBay for a reason now and might need to be returned.
