APX Program the Bluetooth RLN6562 RSM
ohio64thffemt
Ohio
Hey guys
I have a RLN6562 RSM. I recently got the Motorola accessory programming software. I am trying to determine how to program the MIC. do you connect to it with Bluetooth or the USB port under where the Battery is? I have attempted both and not had much luck. I am trying to make sure I am going down the correct path here.
ohio64thffemt
Ohio
I know there isn't but I did plug into the USB and still nothing. It has to be due to being in Windows 10 I'm sure. I'll the info talks about windows 7 and do etc. I can't get it to read with the USB connected in the back.
redbeard
OH, PA, WV Regional Admin
BEE00.348-3.1
Is it still connected via bluetooth when you try? It's really just to update the firmware, as stated above the buttons functions are done in CPS. Did you install the USB driver?
johnoconnor98
Memphis
Connect via the USB port
. I have the software on WIN7, so don't know if it will run on WIN10.
Part of the install is to install "Flip" and maybe java and\or C++. Did those install OK?
edit because I forgot the link! https://www.motorolasolutions.com/c...yprogramingsoftware_customer_installation.pdf
Also, if you are using the bluetooth RSM to connect to the long range mobile mic, you need the Accessory Programming Software to edit the options.
We changed the RSM to automatically reconnect to the mobile mic every time it powered up. Had to use the software, since you aren't connecting to the actual radio
ohio64thffemt
Ohio
Il
Yes absolutely you know exactly what I am talking about. Yes all of those loaded. I hook to the back USB port and a light flashes on the mic for a second than nothing. I knew I needed this software to edit options and that's what I am trying to do. Everything we have is updated to win 10 since 7 isn't going to be supported.
johnoconnor98
Memphis
The operation of the APS software is a little quirky. Are you able to read the RSM?
I'm off for the week so can't see my work laptop. If I remember you have to click something on the menu bar to open the tree on the left window and you will see the serial# of the RSM. Then click the serial# to read it. Or something like that.
There are only like 6 things you can set.
ohio64thffemt
Ohio
No I don't think it's reading. I know there are only a few things but that's what I need. Most think you can program it in the APX/CPS software but you need to change this stuff in the accessory software. It doesn't seem to be reading the RSM
