Programing Richmond/Chesterfield/Henrico Digital Trunking Frequencies
IceBlueEyes579
Hi,
I just recently got a Uniden scanner 996T and I love it. I’m having a problem programming digital trucked systems in the richmond/chesterfield/henrico area. I have followed the instruction manual and did everything that it said. Its scanning the frequencies and it showing that it has a signal (but some time it gets week and then strong again) but its not picking up anything (I also put in some talkgroups). Here are my questions:
I know that’s it’s a Motorola type II Smartzone
When I go to the site type should put P25, 800 MHz standard, or 800 MHz splinter?
Do I need a band plan and if I do where would I find it?
Anything else that I need (That you can think of) /all help would be greatly appreciated
Thanks,
Andrew
dtscho
Fredericksburg, VA
You need to specify 800 MHz standard. You do not need a bandplan. If you want, you can just program the frequencies marked as control channels in the RR database, and the systems should track properly.
Dave
IceBlueEyes579
Thanks!
Hi,
Thank You so much for the help.....I really appreciate it!
Andrew
