Programming a BPR40 (Mag One)
RadioTech19
Pomeroy, OH
I recieved a Mag One radio the other day, and I was wondering how to change some of the frequencys that are out of date. Does anyone know how to program these? Also, I am looking for a lapel mic for it. Not wanting to spend a whole lot of money on this project. Any ideas? Thanks!
N1GTL
CT
DB-9 cable plugs into the lower side mic jack. And you need the programming software from /\/\.
bezking
On the Road
You need an account with Motorola to buy the software. Check out the sticky threads at the top of the /\/\ forum.
Note that you will need a programming cable as well. Get one cheap on eBay. As for the lapel mic you want either PMLN4294D or PMLN4606A.
Bayamon, Puerto Rico
Hi guys, I'm having a bit of a problem programming this little radios. I have an UHF model AAH84RCS8AA1AN and I'm using CPS R02.00 and after following the instruction to put the radio in programming mode with the steady orange light and pressing the read button I get "Communication Error. Unsupported Radio Codeplug Region." Any clues as to what can be causing this ?
SteveC0625
Order of the Golden Dino since 1972
Northville, NY (Fulton County)
The word "region" in the error message suggests that you might have a version of the software that is for another part of the world, most likely South America or European. If you'll fire up the software and look in Help ---> About, you should find the Motorola part number or Series name for the software as well as the revision. It should also say which Region the CPS supports.
The model number of your radio starts with AA which indicates a North American model.
Best I can offer so far.
cabletech
Puget Sound
And there is NO special key press or anything to get the radio into program mode.
The only thing you need to do is have the correct software and cable, then open the software plug the cable into the radio and turn it on and then READ the read amke changes save then write.
Simple as that.
KG4INW
Midlothian, VA
cabletech, have you actually programmed a BPR40? You must hold down the side button while powering up and watch for the light to turn a steady orange before you can program. The CPS even tells you this.
hark2em
BPR 40
I have a BPR 40 UHF 8 channel radio. Can I clone an unprogrammed same radio to work with mine?
Thanks- John
bertedmund67
Unable to Program
Hello everybody,
I am having a tough time programming this little radio. I was wondering what could have gone wrong. I have the cable and software for the AA region know as R02.02 and R02.03. Does anyone know if the same cable that programs the CP200 will also work on the BPR 40? I appreciate any response to this one. Thank you
Bert
bertedmund67
Correct Programming Cable
Hello,
I just want to confirm if the same programming cable that works with the Motorola CP200 will not work with the Magone BPR40. I am having zero luck programming this cable to the BPR40. It always said "communication error please check the programming mode". Thank you
Bert
bertedmund67
No, the CP200 cable will not work.
You need the correct cable. It plugs into the SMALLER (2.5mm) jack on the side of the radio.
It's far from my favorite radio.
Thanks much, I appreciate this comment. What is the difference between these two cables? Both of them have 2.5 mm. Anyways, I will get the cable that assigned only for magone. Thanks again.
Bert
ElroyJetson
The difference is that the CP200 cable WILL NOT WORK.
I don't think it will even FIT.
I never actually tried to fit the 200 cable into a 40 but I think the pin spacing is different and even if they did fit, the pin assignments are different.
bertedmund67
Thank you for the clarification. I gotto get a new cable assigned for that small radio.
Bert
cifd64
Northern Passaic County, NJ
Hello,
Bert
Bert, First, make sure the radio is fully charged. Once it is, remove it from the charger. Trying to program with the radio in the charger is a possible cause. Also, if you are using a USB Interface cable and not the serial 9-pin cable, that can be another problem. However, even with the 9-pin cable, I still get error messages. ESPECIALLY when trying to narrowband.
Fact of the matter is this, BPR40's are not the best radios and the CPS is not the most stable. It takes a few shots at writing sometimes.
Check the items I have listed and get back to us. Or PM me directly. I keep RR.com open when I am at my bench.
