If you have the correct information, you should only need one frequency. (Unless it's a Trunked System.)is there any benefit to programming both transmit and receive frequencies
Hello
I’ve looked around for information on this and feel stupid asking but, is there any benefit to programming both transmit and receive frequencies in a scanner?
The only time I used to do that was when I would get the "our radio doesn't work right" complaint, and I'd scan the bank of frequencies with repeater inputs to listen to what the repeater hears before it retransmits. Cursory diagnostic tool to find if someone played with the MPL/OST (mutiple PL / operator selectable tone - back when that was the thing.) and was on the wrong PL/DPL setting for that repeater.Hello
Some (make that a very few) systems use the repeater input frequency as a direct or "talk around" frequency, using a different access tone than the repeater. It's not a common practice in the USA.is there any benefit to programming both transmit and receive frequencies in a scanner?
You most likely won't hear anything on a TX frequency if you aren't in the immediate area of the transmitting unit (a few hundred yards at the most). Similar to simpex ops. RX frequencies are repeated, that's why you can hear them over greater distancesHello
The few times I saw it, was the repeater output, and the channels were almost always CSQ. This way people would still hear the repeater traffic coming thru.Some (make that a very few) systems use the repeater input frequency as a direct or "talk around" frequency, using a different access tone than the repeater. It's not a common practice in the USA.
