Programming cable
NWI_Scanner_Guy
Dyer, IN
What type of cable is required for computer programming of the BCD325P2? Does it use a USB mini or the type that the BCT15X uses?
Thanks in advance.
NWI_Scanner_Guy
Dyer, IN
You will need to install the driver for the cable to work: Driver Install for the Uniden Bearcat | Scanner Master
Thanks for the link. I have a 325P2 on order and it should arrive tomorrow. I'm already putting together some programming via Freescan, and now that I know I need to install a driver, I shouldn't (hopefully) have any problems uploading everything to the scanner once it's in my hands.
tvengr
Well Known Member
Baltimore County, MD
The owner's manual doesn't provide much information about using quick keys. Here is a PDF file which will be very helpful:
  • Uniden Scanner Quick Key Instructions DMA.pdf
NWI_Scanner_Guy
Dyer, IN
Thanks!! It will definitely come in handy.
It's been a while since I've programmed a DMA scanner, via PC or manually, and I'm a little rusty at it, but I'm sure it will all come back to me.....I hope. LOL!! :D
ladn
To clarify. The cable is just a plain vanilla mini USB cable, but the scanner, itself, will require the USB driver. It's a very easy setup.
Consider purchasing the ProScan programming software. It is a first rate product and well supported here on RR. Initial install give you a 30-day trial.
NWI_Scanner_Guy
Dyer, IN
ProScan has become my "go-to" for programming. Didn't really care for it at first, but it has "grown on me" and it the program I turn to before any others.
NWI_Scanner_Guy
Dyer, IN
If you have any problems, you can attach your programming file(s) and we can check for errors.
So far, so good. I've done just a few systems so far, both trunked and conv, via PC and even gave a "small" trunked system a go manually. It worked, but PC programming is a must for any large systems. Too much knob twisting manually LOL.
ladn
I barely have the patience to manually enter a conventional channel!
I still have a few older scanners, like the BC 760 XLT, with no computer interface, but I mainly use them for frequency searching and aircraft.
