Your RDU4100 is set to use PL tone #1, which is 67Hz.
Your CP200d is set to use DPL 023.
They are essentially blocking each other with the mismatch in PL/DPL settings. You need to make them match.
Set your CP200d to us PL tones and set that to 67hz on both TX and RX.
That resolved it, thanks so much!!! My radios are able to communicate.
I have another question if you have time... My RDU4100 uses diff MHz for subsequent channels, i.e., Channel 1 - 67 Mhz, Channel 2 - 75 Mhz, Channel 3 - 89.9 Mhz, etc. All radios are set to 464.50000 only the Mhz varies on RDU4100. I set the CP200D to match RDU4100 settings. Now CP200D can transmit on 1-5 programmed channels. However, RDU4100 transmits regardless of channel set to (Ch 1-5) to CP220D Channel 1. It's as if CP200D scans all or monitors all channels, but I would prefer it only pickups on channel it is set to, for example Ch 1 on 4100 only transmit to 200D Ch 1. Ch 2 on 4100 only transmits to Ch 2 on 200D. Is there a way to control this on CP200D?
I have the programming software and can attach any detail window needed. Just advise what I should post to provide the information needed to determine correct settings. Thanks again for your help, it is greatly appreciated.
