RickS31
Hi guys,
I was able to listen to all the acts and most of Dobbin's comm.One thing I became clearly aware of is that I still have a lot to learn about programming the little beastie. Specifically the Federal TRS system they use. I was able to follow most of the comm there by just programming the found voice channels as a conventional set of freqs. But I never could get the trunking sys to fly.
After much reading in the Wiki and forum threads I realize it must be setup as a Moto 800/900 system with custom trunking tables. Since it's a 400 MHz system I'm guessing each channel must be specified in the tables based on the base freq (406.3 Mhz), Offset (380) and step of 12.5 khz. I looked at the tables (currently playing in PSREDIT) but I'm sure the others are the same. It also requests ChHi & ChLo. I kind of surmised, maybe way off base, that Ch 00 is 406.3 with offset to 380 and step at 12.5 khz. Maybe Ch 01 is 406.3125 and so on. Have no clue what Ch Hi is. There is where I get lost. Read the calc description but that didn't clear the cobwebs much. Any help would be very much appreciated.
Rick
Rick
