Programming for simulcast P25 systems/sites
19sargeusmc56
So with systems that share a core, how do you setup the different sites? Do you define every site in the simulcast system with RSSI/SYSID's or do you just use FF/FF?
How does this G5 decide what site to latch onto?
jtwalker
BEE00.1E8-1.22 (or) BEE00.689-1.13
I never use the wildcards because none of the systems local to me require it.
On some knobs I use all sites for a wide area system, for other knobs I use the sites in one county, and then will also use one site per knob. It all depends on what control you want/need.
The G pager will lock on to a site with an acceptable quality of decode, then stay with that site until the decode deteriorates.
K9KLC
Southwest, IL
For my local TG's I use the site numbers required. Regarding simulcast, it "just knows" what to lock on on those systems. The only times I use the FFF stuff is for one or two of the knob positions I have set up for roaming scan type stuff, but honestly hardly ever use it.
19sargeusmc56
An example of when wildcards are useful is when the various sites having differing sys-id’s amongst them. This presents an issue for PPS and wildcards get around this.
So the suggestion would be, rather than program 3 sites, all with different sysid's, it would be better to program 1 site, listing all channels from all sites, and use FF/FF?
K9KLC
Southwest, IL
I'll be honest I'm not sure what you're asking here. My simulcast county has probably 6-7 sites, I put in the control channel's listed and poof, it just finds them. Perhaps if this wasn't such a mystery and you told us what you were trying to actually receive it might help us help you.
llzel
St Louis, MO
I would only use one site per knob position. I tried 2 sites on one knob and sometimes my G4 would latch on to one site while all the action was on another. These are simulcast sites.
K9KLC
Southwest, IL
Unless I am doing some traveling and have some kind of "wild card scan" thing going on, I absolutely agree with this. I am confused by what he is asking in the OP. He mentioned simulcast and a core site or something but then goes on with something else. A little clarity would help to answer the question.
jtwalker
I would not do it this way. May work, not sure. I would program each site on their own with correct values unless something about the site doesn’t work in PPS, forcing use of wildcards.
I import sites from a csv downloaded from RR.
Even if I used wildcard value I would keep sites separate.
19sargeusmc56
Sorry. So, using the G5 to listen to the adjoining county that shares the core with where I am. The G5 is not latching on to a local county site when listening to traffic from the adjoining county. Does that make sense how I explained it?
gvvfd801
Huntington
My whole county just switched to a system like this and we are having a issue programming our g2-g3. Its a UHF P25 simulcast system. We have yet to get a pager to alert. They say its the same tones as we had on analog. Can anyone give any helpful advice.
19sargeusmc56
Seems like I'm trying to do the same thing you did. Do you have sites built into your simulcast systems?
Is the county still paging over the analog channel...with it patched into a P25 TG?
