programming issues tyt th-9800
jrock71984
i am having issues programing my th-9800 every time i program it using either chirp or the tyt9800 software i put in the channels with the names i want programmed to the radio and when i write it to the radio none of what i wanted programmed shows on the radio display also after i program it its starts beeping every fre seconds as whenn as locking up some of the keys on the radio and when i push them nothing happens
CopperWhopper67
Have you tried opening the TH-9800 CPS without loading an existing file, and writing a blank codeplug to the radio?
brownalan
Northwest Louisiana
If it was mine I would try this:
Do a full factory reset to get the radio back to operating status.
Use your programming software to READ the radio and get a “blank” program to start with.
Modify the programming as desired and WRITE it back to the radio.
jrock71984
I have tried this with no luck
