Can you zip up the .txt file and try pasting (or drag & drop) it here again.
The Mammoth Mtn. Ski Area radio system is #2. System #1 is quite long.
Programming looks correct other than duplicate frequencies with the same LCNs.
Can you double check that the squelch is not set too low.
{edit} I deleted all systems except the Mammoth Ski Area and all three sites scan. When I set the squelch to 0 then the current site scanning will stay on that site.
With you having success scanning all three sites, I beginning to wonder if there is something wrong with my scanner.
When you change the squelch knob position, does the scanner display show S = 02 then S = 03 and so on?
{edit} Could be the noise floor on your scanner is higher then normal. Try setting the squelch to a higher value.
The scanner displays SQUELCH LEVEL 0, 1, 2 . . . . 15.
I've set the at every level from 0-15. The scanner only scans the first site 'MMSA Summit."
EDIT: For some reason the display show a constant 3, 4. When I push either of those numbers the scanner just beeps and doesn't clear those numbers. This has been going on for a year or more. So I can't scan the systems I have with 3 or 4 system number.
Do this:EDIT: For some reason the display show a constant 3, 4. When I push either of those numbers the scanner just beeps and doesn't clear those numbers. This has been going on for a year or more. So I can't scan the systems I have with 3 or 4 system number.
Do this:
1 Download from the scanner to ProScan just the settings and not the systems. That way the PS settings will be the same as the scanner settings in case a setting was changed on the front panel.
2. Change the SQK 3 and 4 to 0ff like in this image.
3. Upload to the scanner just the settings and not the systems.
I didn't follow all of that, most of all getting the screen shot to come up on my ProScan screen. I went to the Quick Keys/Search Keys tab, which looks a little bit different than your screen shot, unless you cut of the right hand side of the screen when you posted the image. I didn't know how to just upload the settings only, so I just uploaded to scanner. Maybe that is what you meant.
I would do a scanner reset then upload the systems and settings to see if that helps.
Scanner Reset Allows you to initialize the scanner’s memory,
turn off the scanner.
1. Then press 2, 9, and Hold while turning it on.
2. The scanner will give you the option ‘Restore? “Yes”=E/No=”. If you press E/yes, the scanner reloads the preprogrammed systems.
>>>>>>>>>>Important! This deletes all programmed data.<<<<<<<<<
bob does do a lot around here.
to turn off groups 10+ push the .No (thats decimal No key) the first number then the 2nd so if you want to turn on group 37 .No 3 7Now the trouble is I can't scan any of the other systems, except system 10, which I can toggle on and off using the scanner keyboard. I don't know how to get to the other systems (11+) and never have since I've owned the scanner. The scanner's manual and the easier to read version of it, well let's not say it isn't in there, I just can't find how to do this simple task in either of those documents.
