SDS100/SDS200: Programming the SDS 200
Bonkk083
Union, SC
Is programming the SDS 200 like programming the BCD536HP when using Proscan
Bonkk083
Union, SC
What is the housekeeping feature I read about is it bad about missing a transmission
Bonkk083
Union, SC
I have the sds 200 usb plugged in to the pc but it's not showing the screen on proscan do I need to finish initial setup before it will show up on proscan
ProScan
Software Provider
Ontario, Calif.
Do you have the scanner in Serial Port mode (normal operation) and not the Mass Storage mode?
Do you want the display data to come from the USB or LAN connection?
Bonkk083
Union, SC
Is -50 to -60 dbm a good signal
ProScan
Software Provider
Ontario, Calif.
Ensure that the scanner is in Serial Port mode (normal operation) and not the Mass Storage mode.
After that, go to the Comm Port menu and click the Auto Detect button. The SDS200 should show in the list. If it does then select it then click the Set Selected... button.
If it doesn't show in the list then go into the Device Manager and see if the comm. port shows there.
Bonkk083
Union, SC
What does NAC mean and what it does I'm not familiar with it I have it on wasn't sure if I should leave it on ignore or on
Whiskey3JMC
Another Pesky Scanist
Simulcastylvania, TE
From the easier to read manual which I've referred you to on more than one occasion:
Site NAC Operation This allows the scanner to ignore a transmission from a different trunk system that utilizes one or more of the same frequencies that your site uses.​
This allows you to have the scanner ignore or use programmed NAC codes for trunking systems. The default setting is Search.
Scroll to Use Site Nac or Ignore Site NAC and press E/yes.
dave3825
Suffolk County NY
And in addition to what Mr. Yuk said, if its a P25 conventional freq, you only need the nac programmed if there is more than one agency in your receiving area using the same freq. In that case, you would program the freq with the nac, and tag it, then enter the same freq again with the second nac, and tag that also.
Bonkk083
Union, SC
Do I go to the sites to set priority id and can I set priorities like 1, 2, 3 and so on
Bonkk083
Union, SC
What I was trying to say was I have 3 talkgroups can those be put like tg 1 tg 2 and tg 3 while using priority id scan 1 before 2 and 2 before 3 something like that
