Programming VX-3200
KC2EQ
Elmira, NY
I have a 128 channel Vertex VX-3200 that came with CE52 Version 4.85 programming software. Have the software on a Windows 7 machine and it will read and program the radio.
My problem is that the radio came with only one channel programmed (CH 1) and I was able to change the TX and RX frequencies and even add a PL code. I tried to add additional channels and did go into the group 1 settings and changed the number of channels from one to five. The basic screen does now show channels 1-5, with channel one retaining what I had changed . 2-5 are all showing "450.00" for frequencies but I can not change the numbers. What other changes do I have to make so I can enter the data in channels 2-5?
John/KC2EQ
Elmira NY
kayn1n32008
ØÆSØ Say it, say 'ENCRYPTION'
Sector 001
Wirelessly posted (Mozilla/5.0 (BlackBerry; U; BlackBerry 9780; en-US) AppleWebKit/534.8+ (KHTML, like Gecko) Version/6.0.0.600 Mobile Safari/534.8+)
Sounds like the software is in demo mode. You may need to enter a key to allow It to let yoiu program more than one channel. Talk to who ever you got the radio from.
RodStrong
West
Are channels 2-5 grayed out? I might be getting my models confused, but you have to scroll to the line in question and hit the space key or enter to open those up for editing. I unfortunately don't have my software handy to confirm. If that doesn't work, let me know and I'll dig into it further.
Good radio by the way.
yarseno
Double click on the channel number on the left or click it once then hit the space bar...it should open for edit....
kd5ppb
Arkansas
You will probably have to click "Group" and select GRP 1 then enter the # of channels you are wanting.... Without doing this you will only see the # of channels that are listed (ex. if under GRP 1 you only have 3, then you will only see 3 channels in your basic programming).
I am a Vertex Standard dealer, if you have any other questions just shoot them my way and I will do the best I can on helping you find the answer.
I'm looking for older VX3200 conventional software - I have a customer who wants the 2 meter ham band put into his 3200 but my software limits me to 148-173MHz only.
