Tom_G said:
I read that in the manual also.
I wonder if having all the frequencies in the scan list will cause any issues ????
For the record - you don't enter frequencies into a scan list... you ener frequencies into a TSYS object... then you create TGRP objects that refer to that TSYS object and the TGRP objects are assigned to scanlists....
Now back to our program...
Other than extra work on your part, I think entering the other system freqs *could* cause a slight delay while checking all of the freqs for the control channel...
Most systems carry everything they need in the control channel so the radio will already know which frequency to switch to. However, I *think* there may be some old systems that don't have that data in the control channel where you *could* need all freqs programmed (this is very unlikely).
Bottom line is I do not believe there is a heavy downside to entering all of the system frequencies - other than you having to take the time to do it.
