BCD436HP/BCD536HP: programming
kc2wtj
Toms River,NJ
how long does it take for radio reference to update the database for uniden? i saw updates in the rr database and it didnt upload to my scanner
jonwienke
More Info Coming Soon!
VA
Uniden refreshes the Sentinel database weekly, usually on Monday mornings.
You have to download the update into Sentinel, then Write To Scanner before the scanner will have the updates.
kc2wtj
Toms River,NJ
i did and it didnt take it.....maybe i did something wrong? all i know is i hit update database and then i hit upload to scanner... u said every week? that maybe something to it was in the last 48 hrs or so.....
kc2wtj
Toms River,NJ
if you look under nj monmouth cty and look at the 700mhz system those are the updates im trying to to get
jonwienke
VA
Make sure you have the Force Write Full Database option checked when you Write To Scanner.
jonwienke
VA
Update Master HPDB is the Sentinel menu command to download database updates from Uniden.
ProScan
Software Provider
Ontario, Calif.
The HPDB was updated yesterday accordingly to the file dates.
Look here to see if your files are dated 1/29/18
C:\ProgramData\Uniden\BCDx36HP_Sentinel\Database
jonwienke
VA
Look at the bottom left corner of the sentinel window.
chipchap
unidn
anyone here get the 536hp working with mont co. havent scanned for a while
jonwienke
VA
Need the unabbreviated county and state to answer for sure, but if you've updated the database on the scanner and have your location and other settings set correctly, it should work.
jonwienke
VA
What is the date in Sentinel, bottom left corner of the main window?
ProScan
Software Provider
Ontario, Calif.
i tried to update again and it didnt work....any help would be appreciated
If this is the same with database is the current version, try this
1. Exit Sentinel
2. Delete the folder C:\ProgramData\Uniden\BCDx36HP_Sentinel
3. Reinstall Sentinel. Choose Repair option
4. Start Sentinel. You should get a Reconstructing Database message or something to the effect.
5. Try updating the Master HPDB again.
jonwienke
VA
You don't need to uninstall Sentinel. Just go Tools - Options in the Sentinel menu, then click the Start button next to Reconstruct Full Database.
