Proscan audio issues
johnmac
Westminster, Ma
I have just updated my computer to Windows 11 from Windows 10. I have the integrated audio on the motherboard and a dongle audio device. Although I can here the audio from the speakers from both audio devices The audio does not want to connect to my proscan instances, although I do hear them from my speakers. All connections are as they were with Windows 10. Anyone run into this issue and is there a solution?
Thanks,
John
johnmac
Westminster, Ma
I guess I did not explain the problem correctly. I understand how to set up Proscan. This appears to be a Windows 11 issue. I can hear proscan fine, I cannot setup the audio in proscan, when I choose the audio choice, it will not connect to proscan. Some of the audio sources are missing even though they are installed properly. This all worked fine in windows 10
ProScan
Software Provider
Ontario, Calif.
Check the Microphone Privacy settings. Even if using the Line Input.
