Proscan Help
Bonkk083
Union, SC
I can get the audio but I can't control the scanner nor see what is scanning it was working but after the power went out it's been like that
Whiskey3JMC
Surfer of the Delaware Valley Airwaves
Simulcastylvania, TE
Is this for your SDS200? What are you using to control it, remote scanner over IP or web server? Perhaps your IP address changed after power was restored? But first thing's first: Have you restarted Proscan and/or computer?
Bonkk083
Union, SC
It's on the 536, I've restarted the computer and router, It's over IP the scanner shows up on the router
RMason
Mississippi / Colorado
Have you also restarted the scanner?
If restarting the scanner does not reconnect:
In Proscan:
1.Go to the Menu --> Comm. Port.​
2.Click the Port combobox.​
3.Choose URL.​
4.Click the URL Setup button.​
5.Check the IP address of the scanner. Example: --> 192.168.1.5​
Select "Autodetect IP Scanner" if the IP address is not correct.​
6.Click the Reconnect button.​
