PROSCAN recorder input sound device help
RadioChief55
This is a computer that is running 4 feeds and has USB sound cards to for the 4 feed. I am trying to set up an SDS200 via LAN. I have control of the scanner but I can't change the input sound device. Its grayed out and wont do anything when the mouse is on it/ I tried restarting the PC, I tried removing the USB sound card that is in the box, nothing. Any ideas? Thank you
RadioChief55
Turn off the Recorder then you can change it. Just below the screenshot shows Turn Off Recorder To Make Audio Changes
I looked but don't see it, am I missing something. I'm not new at using proscan or programming radios, I just never did the LAN scanning. I posted the picture with the bottom of the record screen. Thanks
ProScan
Software Provider
Ontario, Calif.
It's there. Just need to scroll down or increase the height and you should see it.
RadioChief55
Ok, thanks for all the help. What I was doing wrong was I was hitting the recorder stop button in the recorder it self, not clicking on the record button. I now have audio working.
Next question, can I have multiple SDS200's on the same network set up like this?
RadioChief55
OK, two more questions, do they all have the same IP, do I name them? I'm not sure what a different folder means?
ProScan
Software Provider
Ontario, Calif.
Each scanner will be assigned an unique IP address. Each instance of ProScan needs to be in separate folders. After you install ProScan, just copy that folder or the folder contents to a new folder then change the options pertaining to that instance.
