proscan recorder
W2NTV
Union vale NY
I can't seem to get the recorder to just record what I have flagged. I have gone into the database and checked the appropriate frequencies I want to record. I then went and checked the "LOOKUP FLAG FROM DATABASE" but nothing records.. It does however record everything if I check "ACTIVITY"
TU for any help
Whiskey3JMC
Resident Numbskull
Simulcastylvania, TE
Are you running the latest Proscan version? There was a fix released at version 19.3. Current as of this posting is 23.4
  • Fixed - Recorder - "Lookup Record Flag From Database" broke in ver. 19.2
mr10pt
Lowell, IN
Does he have to select "marked channels" within each system?
ProScan
Software Provider
Ontario, Calif.
Thoughts....
Would reinstalling fix it?
What type of scanner? I never advise to reinstall. All that does is replace the exe file with the same one.
Did you set the system level Recorder option to ‘Marked Channels’?
W2NTV
Union vale NY
Yes... anything i want recorded is checked... the "flag" box is checked.... but nothing records....
Scanner is sds200... (not sure that really matters)
W2NTV
Union vale NY
Btw.... it records everything if "activity" is checked ...so audio setup is right
W2NTV
Union vale NY
when you say "Marked Channels" .... are you saying in the database... picking what I want recorded??? or is there another box Im not seeing???
ProScan
Software Provider
Ontario, Calif.
Click the system node and look for an option 'Recorder'.
