ProScan: ProScan screen colors?
RadioChief55
I have two remote scanners I listen to. They are set up pretty much the same way.
But one displays the screen with multi colors and the sizable screen is bigger and the other will only display one color and the sizable screen is smaller.
The PC that displays multiple colors is the actual colors on the SDS200's screen's.
I put the two side by side to check the settings in the Options / General and they are the same.
What an I missing?
Thank you
Ensnared
Waco, Texas
Ok, I am really confused now. I used to own a GRE PSR 500. I could custom design the colors for the LED.
I do use Sentinel on the SDS 100/436HP.
I cannot clearly see the screen above. So, is it possible to use Pro Scan for more color options? If I also wanted to go into Sentinel after programming in ProScan for something else, what colors would I see in Sentinel?
If I can make different colors for using ProScan, does the software make this possible? I don't know how LEDs are colorized. If I am only limited by Sentinel, I am going to be rather self-annoyed to say to least, LOL.
ProScan
Software Provider
Ontario, Calif.
ProScan gets the color RGB values from the Sentinel Display Customizer (Edit Display menu). There's no way in ProScan to add additional colors. If there was, the scanner wouldn't accept the additional colors. I tried that before.
Ensnared
Waco, Texas
Well, that is what I was dreading to hear. I miss this feature on the trusty old GRE PSR 500. Thanks for responding.
