psr 400 undo updates
tbharper
Lafayette TN
does anyone know how to undo the update on the psr400? the problem im having is iafter i updated it with the latest firmware sunday it slowed the scanning down to a crawl.it takes nearly a minute to scan 25 channels per bank.
fineshot1
NJ USA (Republic of NJ)
Don't know how to do what you are requesting but, before going that route have you tried reseting the scanner's cpu or re-applying the update first? There should be a reset procedure in the manual.
DaveIN
Founders Curmudgen
West Michigan
What exactly is slow about the scan? How are you compairing it to the older fimware?
tbharper
Lafayette TN
ive got 0-5 banks in use at the most each one has about 45 freqs per bank it takes at least 3 minutes to scan all banks when it used to be like 20 to 30 seconds for all banks before the update of 1.3
Smerri
Massachusetts
Just in case:
Check to make sure your squelch is high enough to where it won't interfere. I know when I have the CT/DC programmed in, I don't get static but it will stop my scanning. Just a heads up in case that may have slipped your mind.
As for undoing the update, sorry but I cannot help you there.
tbharper
Lafayette TN
after messing with it some i think my problem is i cant adjust the squelch turning it either way does nothing
DaveIN
Founders Curmudgen
West Michigan
During scan, when you turn the squelch all the way to the left (open) does it stop scan and let you hear anything? How about on a channel in the manual mode?
How many of your channels are using CTCSS/DCS search?
tbharper
Lafayette TN
the problem is the squelch button is messed up if you press in on the squelch button it scans normal release it and it slows to a crawl .talked to gre support and they are going to replace it for me
DonS
Franktown, CO
tbharper said:
don do you work for gre
People at Dayton this past weekend saw me wearing a GRE shirt in the GRE booth, while wearing a badge that said "Don Starr - GRE America".
I don't work for GRE directly. I do have a "relationship" with them, though.
