psr-500 display help
frank125
hello looking to see if there is a way to adjust the second line on the display. it shows freqeucy while its stopped on a transmission then shows id just for a second. is there a way i can make it show the id# a little longer. sometimes i dont catch the id# in time. and would like to see if i can adjust this to make the id# show a little longer thanks for any help in advance.
rdale
Lansing, MI
Yep, extend your LCD BLINK OFF and ON times to something you prefer.
spooney
Indiana
You cannot adjust the blink on-off on that display line. That only works on the 3rd line on a trunk system when it flashes from system info to TG info
rdale
Lansing, MI
Well, on my scanner it flashes between the VC and CC at the same time that line 3 flashes. And I can change them (together) by changing the LCD BLINK times. So I'm not sure what you are looking at...
spooney
Indiana
I don't think that is correct. On my scanner the change on line two occurs when the channel is active. When voice is heard I see the frequency displayed. When the voice drops then I see the TGID displayed. Therefore, the only time the TGID is displayed is during the delay time which is usually very short during a conversation between two radios. I changed my blink rate and it did not change this operation, only the 3rd line.
Am I missing another setting that allows you to do what you say yours is doing ?
rdale
Lansing, MI
We might be talking about two different things... In a wildcard mode, the ID is on line 3, and that's what flashes based on the rate you are using. If you have the talkgroup programmed in, the alpha tag flashes on line 3, and if you have SHOW CC enabled, the CC flashes on line 2.
DonS
Franktown, CO
Line 3:
* Alternates between TGRP alpha tag and TSYS alpha tag. If it's a WC TGRP, the tag will be of the form "*ID: ttttttt", where ttttttt is the active TGID (or "*PC: rrrrrrr" for WC PC TGRPs).
Line 2:
* During the call, shows VC frequency.
* During "delay time", shows TGID for the active TGRP, in the form "ID: ttttttt" or "PC: rrrrrrr".
* If GLOB "ShowCCInfo" option enabled, will alternate CC freq with VC freq / TGID
rdale
Lansing, MI
DonS said:
Line 3:
No, it alternates the CC with VC (not TGID)
And it does NOT show CCInfo on EDACS systems.
DonS
Franktown, CO
rdale said:
DonS said:
Line 3:
First, the quote above is wrong. I said Line 2 shows that info, not line 3.
Second, I'm watching my PSR do exactly what I said:
* ShowCCInfo is enabled
* I'm looking at it during the "delay time" after the active call, while the radio is back on the CC
* Line 2 is alternating between "ID: 11344" and "CC03 488.987500"
EDIT: it wasn't mentioned before, but my above only applies to "SCAN" mode.
Correct.
rdale
Lansing, MI
Ugh - another EDACS difference. Only the ID: remains during delay time, no CC or VC info.
