PSR-500/PSR-600 CPU Firmware U2.1 Released
remay
North Nashville SPRINGFIELD
updates for pro106
I have the same up mentioned. Seems to be working well. Still understanding and lwearnig the sxcanner and it's functions. Thanks
eyes00only
Denver Colorado
Help
What's next? I downloaded & unzipped the update and got 3 different things. Which do I use & how do I get it to my PSR 500? I did one one upgrade a long time ago but forgot how to do it.
JK
fxdscon
¯\_(ツ)_/¯
JK
When you unzipped that download, was one of those three things a PDF file with instructions on how to perform the upgrade?
fxdscon
¯\_(ツ)_/¯
How do I check which version I have, and what do I do if it crashes my $500 baby?
JK
It would be VERY helpful for you to read that instruction file over again.
to answer your first question:
From that PDF instruction file that you downloaded, Quote:
"As noted above, there are two different versions of CPU firmware for the
PSR-500/PSR-600 scanning receivers. To determine which version you should
use, turn your radio off, then turn it back on while holding down the PGM key.
Refer to the “uP Boot Ver:” line at the top of the display to determine the Boot
Version used in your radio." Unquote
to answer your second question, also from the PDF instruction file that you have: Quote:
"Upgrading your scanner is a quick, simple and safe process. There is no way you can
render your scanner inoperable by performing the upgrade." Unquote.
eyes00only
Denver Colorado
Sorry for being stupid, but I am old :)
I got it done and went from 1.8 to 2.1.
Thanks again for your help fxdscon.
JK
pratzert
I was always told that these firmware updates will NOT work on the RS scanner.
What's different about this one to make it work on the Pro-106 ?
fxdscon
¯\_(ツ)_/¯
The last few posts were referring back to post #22 - he was asking about a psr500.
rfgroup
Rochester NY
When I downloaded the file a few hours ago, the file name stated it was for both versions; perhaps they've corrected it now; who knows... These releases this time seems a little hap-hazard...
Forgive me, I am brain dead. I forgot how to check what version Firmware I have in my PSR-500 and 600. I know how to check my uniden. Could you please send me private directions? I am originally from Michigan (Oak Park to be exact) many, many years ago. Thanks.
The 3 key must be pressed while the Welcome/Owner screen is being displayed.
3 displays CPU and DSP versions.
savage308
Belleville , ontario, canada
i baught my psr 500, from the us so do i need the c firmware , didnt think there was a difference in the radios in general , when i press the pgm button mine has 1.4 0n top then under it 1.9
savage308
firmware
ok so i downloaded the firmware did step 1 , proceded to step 2 test, for version then the scanner froze up and nothing friggin works period, ive talked to a gree tecky, i took out the batteries now to wait for 30 minutes to see it it goes back to factory new, the message i got said it did not contain a cpu application code
30 minutes has passed turned scanner back on after inserting batteries, opened the boot f14 utility amazingly it downloaded and rebooted the pc,when i first started this it said on my screen version 1.4 and under that 1.9, now it has the 1.4 and under that 2.1, gre teck has no idea why it failed to update earlierand froze the scanner nothing worked not doing that ever again
