mtitteri
Maybe I'm misunderstanding the object and v-scanner concept. I'm hoping someone can clarify.
I have about 12,000 conventional frequencies that I'd like to load in. As I understand it, the 500/600 series treat conventional freqs, talk groups and search ranges as independant objects.
The problem I'm having is lack of memory for (in this case) conventional frequency objects. The goal would be to have all 12,000 memories AVAILABLE for scan without having to load another v-scanner, which makes the previous 1800 inaccessible. In other words, I'd like to just punch in and out any of the the 20 scan lists without re-loading a v-scanner.
At only 1800 conventional freqs, I'm already out of memory.
I could create mixed batches of segmented 1800 memory groups into v-scanners, but only 1 v-scanner can be active at one time?
Hopefully, I'm overlooking something simple and there is a way of having more than 1800 objects available at one time?
Thanks for your help!
Best,
Best,
