yeah theres a screw up somewhere because I definitely don't have 1.0 on both...
on the update screen it says "F1.0 U1.8"
and im using Windows 7...
Sound like a driver issue and software not detecting scanner as CPU firmware on your scanner is updated to 1.8 for phase 2 update.Their is a update 1.9 for Edacs patch. DSP firmware may not be updated.
Go to start bar and in search bar, type "device manager" under control panel section and click on that icon. Look to see if scanner driver is installed and no errors and highlighted? in yellow, If it is then you need to manually install driver.
I do have the driver, but would have to figure a way to sent it to you if you don't have the CD. The driver is not included on the GRE website as they only give you the, "EZ ScanDG Utility Manager", or on the SD card. It's on the CD the scanner came with. It's in the INF folder. When in device manager. You have to right click the psr-800 and then go to driver tab. Then click update driver. Then click browse computer for driver software. Then click browse. Go to where driver is, if you have CD, goto CD drive letter and then INF folder. Then click next. and you will get a error about unsigned driver, click OK to allow and it sure work.
Windows 7 - How to install unsigned drivers?
