Puxing 888K
topgun2916
Chicago,Il
I have the puxing 888 program installed on my computer to program the puxing 888 radios. I'm trying to program a puxing 888K using the same software & cable, however the software doesn't seem to recognize the 888K radio. Any suggestions?? Thanks.
KC9HI
In the programming software downloads area of 409shop.com, they have a separate download for the 888 and the 888K. I would give the 888K software a try. It could be the data files are compatible (which if it does, would allow you to use the same data file for both radios). Another possibility is that 888K software may be backwards compatible with the 888. And lots of places have the 888K programming software.
Plus, it won't hurt to have multiple radio programming programs installed on your computer. I have nearly 20 installed and sometimes have more than one open at the same time.
Jim KC9HI
topgun2916
Chicago,Il
Thanks for the help with the location of the software. I've downloaded the software program, however I am now having issues transferring the data from the computer to the radio via the USB cable. Suggestions? Thanks for the help..
topgun2916
Chicago,Il
I've tried different ways of programming the 888K. It begans to write the information to the radio, then an error message keeps coming up saying check connection. Any more suggestions. Thanks
