Quantar Life Span
kayn1n32008
ØÆSØ Say it, say 'ENCRYPTION'
Sector 001
As you can see, there is no defined life span. If you can keep it running it will last.
This applies to any station. I know of one Daniels station that has been in ham service since it was installed brand new in about 1994. It’s had a PA failure, but the receiver and exciter are still original.
It’s like anything. If you don’t abuse it, it will work for a very long time.
Jl942264
Thanks all, I learned a lot about these things!
Project25_MASTR
TX-COMU
Texas
I know where 24 sites worth of 9600 trunked VHF Quantars are still kicking.
MRG on 13E comes to mind...
As long as the PS fan doesn't seize they run forever. Reminds me of a Motorola sales rep who sold a manufacturing plant Quantar's in the late 90's two died and got replaced by MTR2000s. One had a receiver module go bad and didn't get replaced (well eventually by a MTR3000) and got put up at the office for a few years. Then the call finally came, PS on the final one nuked itself. Took it to the shop, pulled that bad boy apart and swapped the supplies...started a 20 minute burn in and within 60 seconds that fan hung on the replacement supply. Killed the power, popped the supply apart and replaced the fan...3 years later it's still running.
RocketNJ
Pequannock, NJ
My failure with data service was due to the constant keyup-unkey service they were subjected to cranking out 9600 baud of blazing data !!1!!
RDLAP 9.6
Now THAT was fast! (not). Worked on quite a few of those systems nationwide.
