Tattoooz
I did a programmed search on my Pro-96 using these frequencies: Lo @ 851.575 and Hi @ 853.8375.
I can pick up many digital transmissions on many different frequencies in this range in the downriver area and Detroit area very clearly, however if I program the Downriver Mutual Aid Simulcast system into my Pro-96, I get nothing. No static or anything. I also cannot pick up anything on the Detroit simulcast system either. Same thing, silence. I live in Taylor and should be able to pick up something on these 2 systems. I can successfully receive the Northville and Flat Rock MPSCS systems with no problem.
Any ideas? I have read that the Pro96 has some problems with simulcast systems. Is this the case or is there a custom table I need to enter for these systems or a custom rebanded table?
I'm considering purchasing a new scanner and would also appreciate some advice in that area as well. I'm leaning towards the Whistler Trx-2, which appears to be able to handle anything I could throw at it within the downriver area, albeit encrypted comms of course.
Any help or advice would be greatly appreciated.
Thanks,
Tattoooz
Thanks,
Tattoooz
