Vinnie1224
Does anyone know if the sds 200 gets more distance then the sds100 ??? Has anyone tested the two for range distance side by side ?
They're essentially the same scanner in a different case.Does anyone know if the sds 200 gets more distance then the sds100
"Some SDS200s suffer from a hum problem the SDS100 doesn't have."The SDS200 suffers from the hum problem that the SDS100 doesn't have.
I fixed it."Some SDS200s suffer from a hum problem the SDS100 doesn't have."
There. Fixed it for you.
You weren't very specific but yes for UHF anyway.Does anyone know if the sds 200 gets more distance then the sds100 ??? Has anyone tested the two for range distance side by side ?
