R30 R30 simulcast question
kc5igh
Velarde, New Mexico
Good morning.
One of the capabilities I was hoping for when I purchased the R30 was reasonable reception of P25 simulcast signals. Obviously, I didn't expect to track those trunked sysems . . . I already have a Uniden SDS100 and a Unication G5 for good simulcast reception and trunktracking.
So far, my experience has been that the R30 seems to be able to hear simulcast traffic when it's sitting on a single memory frequency, but not when it's scanning memory channels.
Has anyone else experienced this? If so, is there a programming solution in there somewhere that I'm overlooking?
The simulcast system in question is a Harris UHF (406-420 MHz) network with 14 output frequencies that I've programmed conventionally as P25 channels in the R30. The SDS100 and G5 track the system perfectly.
Any suggestions would be appreciated!
Thanks!
-Johnnie
Hit_Factor
Saint Joseph, MI
Try turning down RFG setting for the freqs, essentially attenuating the signal so you only pickup the strongest tx.
kc5igh
Velarde, New Mexico
Thanks, Hit Factor, I'll give that a try.
That system puts out a very strong signal, so the old simulcast "less is more" adage might certainly be applicable here.
Thanks again!
N4DJC
Upstate
Is this a common situation with simulcast systems, or dependent upon tower locations?
Hit_Factor
Saint Joseph, MI
The problem with simulcast is tx from each tower is received at a ever so slightly different time due to tower locations.
Use techniques that reduce signal from other towers include attenuation and directional antennas.
N4DJC
Upstate
Each one of the four towers in my P25 system show the same frequencies in the FCC database. I can see how a directional antenna would help.
