R7100 antenna recommendations
shortride
S.E. Oklahoma
I would go with the discone for general listening, then if you got hot into monitoring one service, put up a special antenna for that. For example a 6 meter ham beam, 2 meter ham, or FM broadcast antenna. I even built up a stack of home brew beams for the NOAA weather stations on 162mhz. KILLER! :^) No reason you couldn't do the same for rail, air, lowband VHF, satellite, what have you. I also swapped out the 10.7mhz ceramic IF filter (~320khz) for a narrower Murata 110khz job and hooked it up to some Weingard 6065p antennas on the roof. Again, KILLER! The R7100 makes a nice DX rig for FM broadcast if you fix the wide bandwidth that it ships with. Enjoy!
You're getting a little over my head with some of your terminology. I don't know yet what some of those bands are and what frequencies they cover. I've got to do a little research before getting that far along. Thanks for the information.
k3cfc
Silent Key
Beavertown Pa.
The best thing to do is take this terminology and google it. this way you will learn.
K3CFC
