radio shack 163
DickH
How to manuly program
The Pro-163 and 164 need only the four control channels for each system to hear the entire system. Use one bank for each system. Just substitute the freqs. used in your system for the 4 in this example.
First bank will be for the PORTLAND system.
(Each bank has 5 sub-banks, each holding 30 Talk Group IDs.).
The first step is to enter the control channel freqs.
1. Press PGM -> TRUNK -> FUNC, then use the arrows to select a bank.
2. Press MODE, select MOT.
3. Press PGM, select channel number. (use arrows to change channels).
4. Enter the first freq. 858.7125 -> ENT
5. Press MODE until MOT appears -> ENT (MOT will apply to next 3 freqs.).
6. Enter next freq. 858.7375 -> ENT.
7. Enter next freq. 859.2625 -> ENT.
8. Enter the last freq. 859.4625 -> ENT.
9. Press SCAN.
Now it will start "trunking".
There are two trunking modes, OPEN and CLOSED.
In OPEN mode you will hear ALL active Talk Groups.
In CLOSED mode you will hear only the TGs you enter into the sub-banks.
To program the sub-banks.
1. MAN -> PGM -> TRUNK.
2. FUNC - arrow to select bank.
3. Press MODE to select MOT.
4. Press TRUNK to select sub-bank.
5. Enter a Talk Group ID (2 to 5 numbers) -> ENT.
6. Enter then next ID -> ENT.
7. When all IDs have been entered, press SCAN.
