cookjames35
hi everyone I purchased a radioshack pro 2096 scanner and bought the radioshack programming cable then bought the arc 96 programming software for downloading and storing frequencies in the scanner when I hook the cable up scanner display says cloan but when I try and upload everything to scanner it says its downloading but it does not work my guess is I'm having some kind of port problem don't know what to do to fix this also is their anything you can do about the 2096 not supporting nac codes I live in liberty ky everything here is conventional I listen to ksp a lot scanner seems to jump around without the nac any advice would be appreciated thank u
