Radio Shack Pro 37 scanner
mrel
Hello
Is there any kind of add on board that can be add to the PRO 37 scanner to make the scanner pickup ACPO 25 signal/
Thank for info.
mrel
Michael-SATX
San Antonio, Texas
mrel - The only mod that I know of is to restore 800 Mhz coverage on models made before 1995.
This was done back a few years ago when cell phones still used the analog mode - useless now.
What was done was to simply take a pair of side-cutters and cut one leg of the diode labeled: D13.
The instructions were like this: Remove Batteries, Antenna and knobs. Remove the 4 body screws.
Unsolder BNC connector, unscrew 4" Hex/Nuts posts holding upper board. Unplug upper board.
Remove 3 sheilded screws and lift the shield. CLIP DIODE D13. Reassemble the radio and test :))
I wouldn't actaully do this- but you asked about mods to the RS Pro-37 - this is the only one I knew of.
You should start lQQking for a new scanner - do some research and enjoy a new/modern scanner !!!
mrel
Thank for reply.
I know need a new scanner to receive APCO 25.
Big problem is these scanner that can do APCO 25 ,is so costly around $500.00.
Any chance price come down from $500.00 to around say around $200.00.
mrel
Michael-SATX
San Antonio, Texas
mrel, The new digital APCO-25 scanners do generaly list for $499, how ever the Radio Shack GRE/RS Pro-106 Digital handheld scanner is on sale for $399 unitl 3/13. Depending on what you wanted to monitor, you might be able to get by with an older / new much cheaper scanner - but check the facts.
I noticed that the long discontinued RS Pro-2096 (200-0496) just recently got marked down to only $29.97 and of course nobody in the San Antonio area region has any in stock - imagine that :))
The Pro-2096 is a base/mobile model and the RS Pro-96 (200-0526) is also disco'd and at $200.97
and the chance of finding one of these models is low buy hey you will never know unless you call your
local Radio Shack and have them do a "Product Availability" district AND region wide search for
these 2 SKU's : 200-0496 and 200-0526 ... so gQQd luck and I hope you find a GREat deal from RS :)
mrel
Michael satx
I noticed that the long discontinued RS Pro-2096 (200-0496) just recently got marked down to only $29.97 and of course nobody in the San Antonio area region has any in stock - imagine that )
Michael: what need is scanner that do APCO 25 ,that around $200.00.
mrel
__________________
