I think we're all joking a bit here. Seriously, don't buy those last few test sets.Honestly, I’m not sure who’s being serious and whose joking! I’m too much of a noob lol!
-B
-B
How so? All it takes is takes knowledge. It's a poor technician who blames his test equipment.Seems to be turning into a thread on how to detune your receivers.
Sorry, didn't mean to offend. Honestly, I think you should reserve judgement until after you use some test equipment that I designed.How so? All it takes is takes knowledge. It's a poor technician who blames his test equipment.
As has been said, calibration is key. Having access to someone else's calibrated equipment is helpful. Anyone have experience with particular GPSDO models in the <$200 range? Is it really just a matter of plugging it into your 10 MHz external reference port and you get <0.1 ppm accuracy? Any thoughts on a budget-conscious calibration standard for RF and AF power levels?
I bought an HP8920B a few years back. It was ex Ericsson Lynchburg. Probably from a lab. Absolutely no dust inside and operates flawlessly. I would recommend one of these models for conventional FM mobile work. Be sure to get the option 102 SPECTRUM analyser and tracking generator.
I enjoyed the trip down memory lane.
As far as the topic at hand, depending on what you're working on, you might be able to get away with an older analog service monitor, supplemented with an SDR and software like SDR# and plugins, LTRAnalyzer, DSD+ (fastlane), PDW, SDRTrunk, etc. to decode various digital modes. Most digital radios have test modes that you can use to get the RF side of things aligned. Unless, you're going to be digging into the intricacies of the digital protocols (somehow), working on some site equipment, etc., that will get you there without breaking the bank.
ObClassicServiceMonitor:
You can get a useable GPSDO for under $100, I have a couple of these that work fine and for a little more you can get one with programmable output freq for about $160.
It’s an oven stabilized rubidium reference or nothing!!! Actually, I don’t even have a service monitor, but I’ve been in plenty of big post production studios that use 10MHz rubidium master clocks to distribute word clock to every suite in the facility… big bucks for those!
-B
I've always wondered what was really involved to check/calibrate some bench equipment. I have a Leo Bodnar GPSDO for my 9700 that is on all the time. Never thought about its parallel use bench equipment.Rubidium doesn't have to be that expensive. I put one together using an Efratom Rubidium module that was sold cheap years ago and built my own power supply and enclosure. It works fine but it also has a finite lifespan when running and I prefer using a GPSDO, especially a tiny one made in the UK by Bodnar. Its about the size of a Zippo cigarette lighter and locks up very fast.
Ya, I’ve always wondered about the lifespan of those… still doesn’t stop the studios from spending $7k on one! Maybe you should start a business!! Sounds like you could corner the market!!!Rubidium doesn't have to be that expensive. I put one together using an Efratom Rubidium module that was sold cheap years ago and built my own power supply and enclosure. It works fine but it also has a finite lifespan when running and I prefer using a GPSDO, especially a tiny one made in the UK by Bodnar. Its about the size of a Zippo cigarette lighter and locks up very fast.
-B
Antelope Audio 10MX Atomic Clock
Rubidium atomic clock perfectly suited to recording, mixing and mastering environments supporting sampling rates up to 768 kHzvintageking.com
P.S. These, BTW, usually run 24/7! How long does something like this last running continuously? Seriously, @prcguy if a GPSDO is just as accurate, a competing product would really be something!!!
Current as it is used, it's set at 49.152MHz, but the Bodnar can be set at anywhere between 400Hz and 810MHz.Is your Bodnar on the 40 something MHz master osc freq with the injection board or are you feeding 10MHz to the back of the radio?
