Running Radiofeed 8.1 and cannot get Let's Encrypt to work. Unsecure HTTP works, and I have set up port forwarding, but I sill get Challenge Failed. Any ideas would be greatly appreciated.
Offhand, I don't believe the Challenge exemption shows any details on why it fails. You may want to try Wireshark or another sniffer to verify that.Disabled Windows Firewall and confirmed Port 80 works in unsecure mode - still no luck. Is it possible to see the detailed Let's Encrypt response in order to see why the Challenge failed?
What exactly are you having trouble with?I still cannot get RadioFeed to work. Has anyone actually been successful using 8.1 with HTTPS?
community.letsencrypt.org
The validation process?It appears that RadioFeed does not support Let's Encrypt certificates currently. Maybe they changed the way it works?
Oh Please. Many people are using RadioFeed and ProScan wth x509 certs. RadioFeed uses the same code as ProScan.Cannot go the manual cert way, as RadioFeed does not host a file structure where files can be written and read, at least not that I can find.
