RadioFeed Version 7.0 Just Released!
ProScan
Software Provider
Ontario, Calif.
  • Added - BC125AT, BCD160DN, & BCD260DN scanners support.
  • Changed - Upgraded the Web Server built in audio player.
  • Fixed - The Let's Encrypt function broke in the Web Server due to a change on the Let's Encrypt side.
  • Fixed - The Web Server feature was causing the program to lock up intermittently.
ProScan Website
Text Tags supported for the BC125AT, BC250D, BC296D, BC346XT, BC346XTC, BC780XLT, BC785D, BC796D, BC898T, BCD160DN, BCD260DN, BCD325P2, BCD396T, BCD396XT, BCD436HP, BCD536HP, BCD996P2, BCD996T, BCD996XT, BCT15, BCT15X, BCT8, BR330T, HomePatrol-1, HomePatrol-2, PRO106, PRO107, PRO18, PRO197, PRO2052, PRO651, PRO652, PRO668, PSR310, PSR410, PSR500, PSR600, PSR800, SDS100, SDS100E, SDS200, SDS200E, UBCD3600XLT, USDS100, WS1040, WS1065, & WS1080 scanners.
ProScan Website
Thanks so much for the update to the software. I like the lower bitrates, I had been wanting to use them but did not want to switch software. I had a question about the metadata from file feature and was not sure where to post it so if this is in the wrong spot I am sorry.
I have set up version 7.0 the same as the version 6.1 that I have been using and all I get for metadata is whatever I put in the " Text to show during scanning" text box. I normal use a file called metadata.txt and read the last line but I can't get it to read the file in the new version 7.0? It is probably me. I just thought maybe someone was having the same problem and could steer me in the right direction.
Thanks again for all the hard work and the great software :)
ScottPDX
Portland,OR
Bob,
I took a look at what YouSaid above was describing, and so I enabled the Metadata tab, File option, created a file in the same folder as RadioFeed 7.0, say named: "test.txt", which contained "Hello World" (without quotes) as text created from Notepad.
But it would never show "Hello World" on the browser in the Metadata field. It would always show: "Scanning".
My only control for the Metadata tab seems to be either choosing None, or any of the other three options. The other three options all only show whatever is shown in the RadioFeed.cfg at: [METADATA SCANNING TAG]=Scanning
ProScan
Software Provider
Ontario, Calif.
Bob,
I'll look at it before the next release. It may be a month or two as I'm working on finalizing the 160/260 support
YouSaid
Bob,
Thank you Scott for trying and wish you had gotten better results. I guess I was not up too early and getting my folders and file confused LOL. Your efforts are appreciated.
Hi Bob/ProScan,
I had tried everything and wish I could have just posted a "Thanks". I understand your busy and will keep using 6.1 where I need the metadata from file and awaiting the next release. Thanks again for awesome software.
ScottPDX
Portland,OR
YouSaid,
Thank you for reporting your discovery.
Scott
tspainiv
Shelby Co DB Admin
Collierville, TN
After updating, for some reason RadioFeed won't remember my Broadcastify login info. I have to sign in every time the program restarts and have to setup all my options each time. I have the "Remember Me" checkbox checked. Am I missing something obvious?
ProScan
Software Provider
Ontario, Calif.
Anyone having any issues with RadioFeed, email me a bug report so I can send test files to verify it's fixed then I can put out the next version.
Bug Reporting
If you discover a bug, send an email to support@proscan.org. The advantage of email is so I can ask questions and send you production quality files with additional testing to help fix the bug. The person reporting the bug will get the fix sooner than waiting for the next release. Put "bug" in the Subject line.
Bug Reports - Advise on the following:
  • Product (ProScan, Free Client, or RadioFeed):
  • Version:
  • Scanner type:
  • Scanner firmware version (if applicable):
  • OS type:
  • Options pertaining to the bug:
  • Describe in detail what the bug is doing or not doing:
Indianabrad
Jasper County, IN.
Bump, Bump: @ProScan, I am trying to use RadioFeed 8.2 to stream my SDS200 to my long existing BCFY feed (I prior had a TRX-2 on my feed). But I can't find the setting in Radiofeed to set the scanner type. I also can't find any setting in Radiofeed to use a LAN IP address to connect to the scanner (which I have a reserve IP set on my router for my SDS200). But I can't even find the menu in Radiofeed to choose it.
ProScan
Software Provider
Ontario, Calif.
1 Go to the Metadata tab
2 Click the scanner box
3. Choose SDS200 in the Type box
4. Choose URL n the Port box
5. Click the URL Setup button.
ProScan
Software Provider
Ontario, Calif.
Thanks for the reply. The metadata panel isn't an intuitive place to put the scanner choice menu and no one would ever guess that it was on that panel, my $0.02.
It's been that way from day 1 and no one ever questioned it before or wasn't able to find it.
Bump, Bump is being pushy. I was going to delay my response by a day.
Just my $0.03.
ProScan
Software Provider
Ontario, Calif.
Still doesn't make it a good location for it.
I think it makes perfect sense. Considering that the scanner type is used only with the metadata or another way of saying it is, the metadata or text tags in the scanner protocol are just one source of the metadata or text tags.
ProScan
Software Provider
Ontario, Calif.
Then rename the tab to "Scanner Settings" and not a tab name that makes you think it's only for metatags. So you don't have to hunt your axx off and never find the scanner type setting.
It is. The scanner settings are used only with the metadata. Some may use RadioFeed for the audio only especially on unsupported radios and a 'Scanner Setting" tab may be confusing or imply that a supported scanner is required.
