radius sm 120
cbrrider06
hello i am trying to program this radio the sm 120. I read the codeplug, change the code plug, and them save the codeplug back to the radio. Question is while I am scanning I can only hear what is on the channel on the display. Is there something I am doing wrong, to why it will not scan????
cbrrider06
yes I have done everything that I can thinks of but it will not scan.
gary123
be sure that the mic hang up is enabled. Remember that the display dosnt change untill an active channel is picked up when the unit is in scan.
GTR8000
NY/NJ Database Guy
BEE00
More specifically, the mic has to be grounded (usually via the mic hook being grounded to the radio itself or to the vehicle chassis) before a lot of Motorola mobiles will go into scan mode. Unhooking the mic breaks the ground, which generally causes the following to happen: - disables scan mode - reverts to the last selected channel or "home" channel - disables the receive PL/DPL putting the radio into CSQ receive mode so you can monitor for channel activity.
cbrrider06
Thanks guys I was not thinking. Here was my intentions. I was going to install this radio just for the purpose of listening. But by reading what you guys have posted, the mike must be pluged in and in the mike hanger. I noticed with the mike unplugged the scan icon would blink. but plug it in and put it in the hanger, and it would just stay on. Everything works fine now Thanks alot for the help!!!!
GTR8000
NY/NJ Database Guy
BEE00
If you really don't want the mic connected, there is a simple way to make a jumper using a 10 cent RJ45 modular plug and a short piece of thin insulated wire that would keep the radio in the "mic on hook" state. If you or anyone you know works with CAT5 LAN cables, you could make it in about 20 seconds. If you would like to know which pins to jump, let me know and I'll post the info. I'm not posting it outright because I want to make sure you first understand that jumping the wrong pins CAN and probably WILL fry the radio!
GTR8000
NY/NJ Database Guy
BEE00
You need to jump pins 3 (Hook) and 4 (Ground). These would be the 3rd and 4th contacts from the left when looking at the contacts side of the RJ45 plug (contacts facing up, tab facing down). Should be easy to see in the photo.
